Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Can not install the intel sgx sdk on windows
Samson-hjh
I used to install the intel sgx sdk on my windows computer. But I reinstall the visual studio 2017.
Now, I want to reinstall the intel sgx sdk for the new vs2017.
The intel sgx sdk version is 2.16.101.1. I have changed the bios sgx status to enabled.
The problem is:
When I double click the .exe file. It show nothing after this
when I changed the configuration of the .exe file to make it compatible with win8 like this.
the .exe file works. but there is new problem
I check the solution of this error. but the solution only works under the win8.
then it become confused for me.
Anyone can help me?
Sahira_Intel
Hi Samson,
The supported operating systems for the Intel® SGX SDK installer are:
o Microsoft Windows* 7 64-bit version
o Microsoft Windows* 10 November Update (version 1511) or later, including
versions 1607, 1703, 1709, 1803 and 1809
Any other OS Version is not validated so we cannot guarantee that it will work. Please try installing the SGX SDK on any supported OS.
Sincerely,
Sahira
Sahira_Intel
Can you please clarify what the error was? Were you unable to install the Update for Universal C Runtime?
Sincerely,
Sahira
Samson-hjh
Thanks for your reply.
I think the error is that I can not execute the Intel SGX SDK for Windows v2.16.101.1.exe. It always flashback directly after the progress bar appears. And I try to change the compatible configuration of the exe file. It was able to enter the installation interface, but it reported an error that Update for Universal C Runtime is required. I guessed this should be a problem with the system. What I need to solve is that the .exe file always crashes when I don't change the configuration.
by the way. I installed the intel sgx sdk before. but I can not uninstall it.
Sahira_Intel
Hi Samson,
Sincerely,
Sahira
