Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Critical Error in Event Viewer
Dominik_K_
AESMService: SGX is Disabled at AESM Service startup. That's the error, it happens always when i start the PC.
you_w_
New Contributor III
Hi Dominik:
Please check if SGX is enabled in your BIOS menu.
you
Shivananda_H_Intel
If its already enabled in BIOS, you can try reinstalling PSW and SGX Driver .
Lipin__Stas
Hello. Constant critical error AESMService: SGX is Disabled at AESM Service startup
