Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Dllmain() in SGX
Sam5
Can the untrusted process load the dll via LoadLibrary so as to automatically execute the codes in Dllmain()? Or should we still need to create an enclave first so as to call the Dllmain() function in it?
-Thanks
Surenthar_S_Intel
Hi Sam,
sgx_create_enclave has more input and output parameters when compared to LoadLibrary(Ex) function call. So you cannot load an enclave DLL using LoadLibrary(Ex). It may work (I am not sure, haven't tried it), but if it does you would have a 'normal' DLL, not an enclave.
-Surenthar
Surenthar_S_Intel
Hi Sam,
-Surenthar
Sam5
Thanks Surenthar...
