Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1556 Discussions
Do Intel SGX processor use any Criptographic method to make data secure?
Muthumanickam_V_
1. When there are instructions passed between the Enclave memory and the CPU, is there any encryption and  decryption logic involved in between Enclave and CPU?
2. Can I create a windows service using SGX. What will be the issues if I use the SGX developed service in an non SGX machine?
3. In case If I have to send a secured messages from one windows service to the other windows service with in a machine, Would Intel SGX be useful? Basically I am looking to secure my messages that are passed between services.
Muthu
PadmaPriya_M_Intel
The instructions are encrypted while passing it to CPU and it is decrypted inside the CPU cache. The enclave memory is encrypted using industry-standard encryption algorithms with replay protection.
• Tapping the memory or connecting the DRAM modules to another system will only give access to encrypted data.
• The memory encryption key changes every power cycle randomly (for example, boot/sleep/hibernate). The key is stored within the CPU and is not accessible.
SGX doesn’t supports Windows services
Francisco_C_Intel
I wanted to clarify
Although you cannot create a Windows service inside an enclave, you can write a Windows service that loads an enclave. A different Windows service could load the same or a different enclave. Those two enclaves could then perform local attestation and talk to each other.
I believe this would meet your requirements.
