Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1557 Discussions
EPC allocation policy on multisocket machines - Intel(R) Xeon(R) Gold 6348 CPU @ 2.60GHz
boukhari
I am writing an intel sgx application on a multisocket machine. I am running some benchmarks and I need to do numa aware allocation inside the enclave. Is there a way I can force the enclave to allocate EPC pages on a specific numa socket? If that's not possible, how can I check on which numa socket are the epc pages being allocated? Is there a default policy for allocation?
Cheers,
Yassine
Sahira_Intel
If you are using Linux kernel 5.13 or newer with the SGX driver built in, it already has basic NUMA-aware allocation build in. This means that it will try to allocate all required EPC for a given enclave on a single CPU (so it won't span memory allocation across the sockets). You can read more about the patch here.
Sincerely,
Sahira
Sahira_Intel
Sincerely,
Sahira
boukhari
Is there a way to force the enclave to do cross numa allocation? I need this feature to do some benchmarking regarding the memory access latencies in case of cross numa memory access ?
Sahira_Intel
There is no out of box way to force the enclave to do cross numa allocation. You would need to modify the kernel driver in order to accomplish this.
Sincerely,
Sahira
