Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Error: No cache data for this platform.
a3p
when using dcap reference implementation the pccs service errors with
2022-07-05 15:23:38.130 [info]: Client Request-ID : 0e0ca942b98049b097....
2022-07-05 15:23:38.939 [info]: Request-ID is : 4f211ee2b16a494a8119a958c0a048eb
2022-07-05 15:23:38.941 [error]: Error: No cache data for this platform.
at Proxy.getPckCertFromPCS (/opt/intel/pccs/services/logic/commonCacheLogic.js:86:11)
at processTicksAndRejections (internal/process/task_queues.js:95:5)
at async LazyCachingMode.getPckCertFromPCS (/opt/intel/pccs/services/caching_modes/cachingMode.js:126:12)
at async Proxy.getPckCert (/opt/intel/pccs/services/pckcertService.js:115:16)
at async getPckCert (/opt/intel/pccs/controllers/pckcertController.js:77:25)
according to this page
https://www.intel.com/content/www/us/en/support/articles/000059239/software/intel-security-products.html
this indicates an outdated BIOS, but that's not the case.
the board is supermicro X12SPL-F and the cpu is a Xeon Silver 4310
Sahira_Intel
Make sure you are using BIOS rev. 1.1a or newer.
You will also need to make sure that Intel SGX is correctly enabled on your motherboard. Here are the instructions for doing so with your board: https://www.supermicro.com/manuals/other/X12DP_X12SP_Intel_SGX_Support.pdf
If you have done this already, please let me know.
Sincerely,
Sahira
Sahira_Intel
Sincerely,
Sahira
