Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Errors in using Intel SGX SSL
SHU_Y_
Hello.
I'm now developing a simple test sgx application using intel sgx ssl, There are lots of errors after running my makefile.
have built the libsgx_sgxssl.a,libsgx_tsgxssl_crypto.a and libsgx_usgxssl.a,but when i used the "libsgx_sgxssl.a,libsgx_tsgxssl_crypto.a and libsgx_usgxssl.a"
there are some errors:
/home/abc/intel-sgx-ssl-master/sgxssl.1.9.100.99999/lib64/debug/libsgx_tsgxssl.a(tsocket.o): In function `sgxssl_gai_strerror':
/home/abc/intel-sgx-ssl-master/sgx/libsgx_tsgxssl/tsocket.cpp:218: undefined reference to `strerror'
/home/agc/intel-sgx-ssl-master/sgxssl.1.9.100.99999/lib64/debug/libsgx_tsgxssl.a(tstdlib.o): In function `sgxssl_getenv':
/home/abc/intel-sgx-ssl-master/sgx/libsgx_tsgxssl/tstdlib.cpp:69: undefined reference to `strcmp'
/home/abc/intel-sgx-ssl-master/openssl_source/openssl-1.1.0f/crypto/ct/ct_vfy.c:112: undefined reference to `memcmp'
/home/abc/intel-sgx-ssl-master/sgxssl.1.9.100.99999/lib64/debug/libsgx_tsgxssl_crypto.a(ct_log.o): In function `CTLOG_STORE_get0_log_by_id':
/home/abc/intel-sgx-ssl-master/openssl_source/openssl-1.1.0f/crypto/ct/ct_log.c:299: undefined reference to `memcmp'
So how could i solve the problem ?
and how to use the "libsgx_sgxssl.a,libsgx_tsgxssl_crypto.a and libsgx_usgxssl.a," ?
Thanks a lot!!
Alaa_K_Intel
Can you please give some more details? what libraries are you linking (apart from SGX SSL libraries), OS, SDK?
Maybe you've missing linking  some SDK required libraries? (sgx_tstdc.a?)
You also can look at test_app makes files to get an example of SGX SSL make files.
Alaa
