Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Execute sleep() inside an enclave
Shredha_K_
Is it possible to execute a sleep() inside an enclave.
Thanks in advance
Anusha_K_Intel
Os calls(sleep()) cannot be used directly inside the enclave. We can use an OCALL to execute them.
Anusha_K_Intel
Shredha_K_
Thank you Anusha :)
chaoshun_z_
OCALL may not safe since the sleep action will be performed by untrusted part​, so I implemented sleep by using "sgx_get_trusted_time"
you_w_
New Contributor III
I think If you really need this, just make an OCALL. But in this way the time sleep()ed may not be accurate.
