Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Fail to create demo project following "Intel® Software Guard Extensions User's Guide for Windows* OS"
Changzheng_W_Intel
HI
I'm new to SGX. I try to create a demo project as "Intel® Software Guard Extensions User's Guide for Windows* OS" suggested. But in the step that "Import Enclave to Application", I try to followed the guide as below
To call the enclave interface in the application, import the enclave to the application using Microsoft* Visual Studio* Intel® Software Guard Extensions Add-in.
1.
Right click the application project and select Intel® SGX Configuration -> Import Enclave.
The Import Enclave dialog box opens.
2.
Check the sample_enclave.edl box and press OK.
But in my VS project, the "import enclave" is gray as shown in attached file.
Is there anything wrong?
My VS version is 2012, sdk version is "Intel SGX SDK for Windows v1.1.30214.81"
Surenthar_S_Intel
Hi Changzheng,
Intel SGX SDK for Windows v1.1 Support below requirement
Software Requirements
Microsoft Windows* 7/ 8.1/10 64-bit version
Microsoft Visual Studio* 2012 Professional/Ultimate Edition only
Intel® Parallel Studio XE Professional Edition for Windows* Version 2013
Supported Languages
Enclave binding interface supported in C/C++ only
I think are you importing the enclave in enclave project itself. you need to import the enclave in application project.
Please find the sample application in the below link for your reference
https://drive.google.com/open?id=0B4N3YNdBPBe8TG1jMVNGWGtzWTg
Thanks and Regards,
Surenthar Selvaraj.
Surenthar_S_Intel
Hi Changzheng,
Supported Languages
Thanks and Regards,
Surenthar Selvaraj.
Changzheng_W_Intel
Surenthar Selvaraj. (Intel) wrote:
Hi Changzheng,
Supported Languages
Thanks and Regards,
Surenthar Selvaraj.
It's cool! Thanks!
By the way, I read the code in sample_enclave project you suggested, for my understanding, I should create a enclave project and my application project. The application project will call such as sgx_ecall() to create enclave and perform functions in enclave. The enclave project contains the functions which I want to perform inside the enclave. Is that right?
Surenthar_S_Intel
Hi Changzheng,
Yes, application project will call such as sgx_ecall() to create enclave and perform functions in enclave. The enclave project contains the functions which I want to perform inside the enclave.
Thanks and Regards,
Surenthar Selvaraj
Changzheng_W_Intel
Hi Changzheng,
Thanks and Regards,
Surenthar Selvaraj
Hi Surenthar
Thanks for your great help, I have a complementary understanding for SGX project.
Currently, I would like to build a sample application based on OpenSSL library using SGX simulation.
I have installed the latest released linux sdk on ubuntu 14.04 server. I have a question that is there any user guide about SGX project in linux enviroment, and is there already any open source project involved SGX in real life?
Changzheng
Surenthar_S_Intel
Hi Changzheng,
Please refer the below link
  1. Intel® Software Guard Extensions SDK for Linux* OS (Developer Reference) - https://01.org/intel-software-guard-extensions/documentation/intel-sgx-sdk-developer-reference
  2. Intel® Software Guard Extensions Developer Guide - https://01.org/intel-software-guard-extensions/documentation/intel-sgx-developer-guide-0
  3. Intel® Software Guard Extensions Installation Guide - https://01.org/intel-software-guard-extensions/documentation/intel-sgx-sdk-installation-guide
Thanks and Regards,
Surenthar Selvaraj
Changzheng_W_Intel
Hi Changzheng,
Thanks and Regards,
Surenthar Selvaraj
It's great , Surenthar!
Thank you so much
Surenthar_S_Intel
Hi Changzheng,
Please refer the below link for sample code build on Linux SGX SDK
https://github.com/01org/linux-sgx/tree/master/SampleCode
Thanks and Regards,
Surenthar Selvaraj
Esmond_L_
I've followed the instructions on the SGX SDK Installation Guide for Linux OS, skipping the driver and PSW installations for now to try to set up a viable Eclipse dev environment. The Eclipse Plugin is "installed" however, I do not see SGX Preferences under the Window -> Preferences menu to be able to point to the SDK directory. I have tried both Mars.1 and Mars.2 versions of Eclipse but have not been successful. Please advise.
Surenthar_S_Intel
Try to uninstall Eclipse application, SGX SDK as well and start a clean installation following the installation guide. We recommend to install Eclipse , Eclipse Plugin for SGX, SDK SDK in order respectively. Make sure to satisfy the system pre-requisites mentioned in the guide.
-Surenthar.
Surenthar_S_Intel
Resolve all those issues by installing Java 8 on Ubuntu. Once you do that, the SGX Eclipse Plugin preferences, context menus, and wizards will be available.
sudo apt-add-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
sudo update-alternatives --config java
Good luck!
Roshan_Mehta
I have installed Build the Intel(R) SGX SDK and Intel(R) SGX PSW Package as mentioned on https://github.com/01org/linux-sgx
I wanted to ask can I use Intel Parallel Studio XE cluster for SGX development? If yes what steps I need to follow?
system configuration:
Ubuntu 16.04, 64 Bit.
