Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Getting Intel PCS server returns error(404)
jgnoonan
I am confused on how this is supposed to work with Azure Confidential Computing with Intel SGX virtual machines.  I am running this VM with Ubuntu 20.04.  I have installed the Intel SGX SDK, as well as the AESM and PCCS Services.  My sgx_default_qncl.conf file looks like this:
  "pccs_url": "https://localhost:8081/sgx/certification/v3/",
  "use_secure_cert": false,
  "collateral_service": "https://api.trustedservices.intel.com/sgx/certification/v3/",
  "pccs_api_version": "3.1",
  "retry_times": 6,
  "retry_delay": 5,
  "local_pck_url": "http://169.254.169.254/metadata/THIM/sgx/certification/v3/",
  "pck_cache_expire_hours": 48,
  "custom_request_options" : {
       "get_cert" : {
          "headers": {
              "metadata": "true"
          "params": {
             "api-version": "2021-07-22-preview"
When I run the PCKIDRetrievalTool, it generates the csv and repoorts that the file was successfully sent to the cache server.  It seems that a part of the process is missing, namely registering the server (VM).  In my application, I am getting a failed to renew attestation error, attestation data invalid: No evidence provided on handshake start.  Any guidance would be greatly appreciated.
jgnoonan
Scott:  Thanks.  So it turns out my client did not install the Intel Microcode updates to their VM.  They claimed they had, but in fact, hadn't.  Once that was done, and the system rebooted, we rebuilt the enclaves including the flags recommended by the CVE docs, the issue was resolved.  Everything is up and running and I will accept the solution.  Thanks again so much for your help.
Problem resolution:
1.  Ran
sudo apt update && sudo apt install intel-microcode -y
2.  Rebooted Virtual Machine
3.  Rebuilt enclaves.
jgnoonan
Roman if you need help let me know.
castleapp
If the Intel PCS server returns a 404 error, it means the server or resource is unavailable. Check if the URL is correct, the server is online, or if updates or changes have occurred in the service configuration.
