Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Help:installing SGX PSW 1.9 on Ubuntu 16.04 64bits error
SHU_Y_
When i installed SGX PSW 1.9 on Ubuntu 16.06 64bits, it showed that
 "x86 Intel SGX PSW Package can not be installed on x86_64 platform"
I wonder how to solve the problem...
Thanks!!!!
Haitao_H_Intel
did you build your own installer or downloaded from somewhere? For latter case, could you give the URL where you downloaded?
Official release (https://download.01.org/intel-sgx/linux-1.9/sgx_linux_ubuntu16.04.1_x64_psw_1.9.100.39124.bin) only supports x86_64.
SHU_Y_
Official release (https://download.01.org/intel-sgx/linux-1.9/sgx_linux_ubuntu16.04.1_x64_...) only supports x86_64.
Hello
Thank u for your response.
I downloaded the SGX SDK master from http://github.com/o1org/linux-sgx
$make sdk_install_pkg
the result is"Generated sdk installer:./linux/installer/bin/sgx_linux_x86_sdk_1.9.100.39124.bin"
And then I used the sgx_linux_ubuntu16.04.1_x64_psw_1.9.100.39124 and sgx_linux_ubuntu16.04.1_x64_psw_1.9.100.39124 in place of the x86sdk and x86psw. Both of them are successfully installed.
