- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hello
I have tried to debug a very simple sgx program step by step,
and then it appeared the page that "No Symbols Loaded",
it showed that "sgx_urtsd.pdb not loaded"
"sgx_urtsd.pdb contains the debug information required to find
the source for the module sgx_urtsd.dll"
so how could I solve this problem?
Thanks so much!!
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
You need to change the debugging properties to $(OutDir) from $(ProjecttDir) under Project Properties->Configuration Properties->Debugging->Working Directory.(Both Enclave and Application) Select the Intel(R) SGX Debugger.
Could you please use the code in the attachment for your reference.
-Surenthar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
-Surenthar
Hello
Thanks for your response.
I have used the code in the attachment and changed the debugging properites as stated above.
But it still shows that "sgx_urtsd.pdb not loaded"?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Could you please share your system configuration and which version of SGX and Visual Studio IDE are currently using?
-Surenthar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
My operating system is WIN10 professional(10.0 14393).
SDK:Intel SGX SDK for Windows v1.6.101.33581.
PSW:Intel SGX PSW for Windows v1.6.101.33229.
Visual Studio IDE:Microsoft Visual Studio Ultimate 2012 Version 11.0.61219.00 Update 5.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am using the same configuration (except VS 2012, i am using VS 2013) and build the sample code which i shared with you. I am able to successfully debug the program.
Please share your code with me. i will check with my machine and let you know.
-Surenthar Selvaraj
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
