Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
How are Provisioning and Quoting Enclaves launched
AB_
I understand that Provisioning Enclave (PvE) is a special enclave. Please clarify the following questions.
  1. How is the PvE launched?
  2. What does it mean that it is provided by Intel? Specifically, is there a  priviliged software (provided/used by Intel) that creates and launches PvE, and that is somehow not accessible to application developers? I am assuming that sgx_create_enclave() cannot be used to create this special enclave.
  3. Is that a software run enclave or a microcode run?
  4. I have similar questions for Quoting Enclave too. How is this launched?
you_w_
New Contributor III
Hi AB.
To find out answer of these questions, I advise that you can read the source code of PSW. All the achitecture build-in enclaves are inside the PSW package.
Regars
you
Rafal_W_
Architectural enclaves are loaded by the aesm service "when needed". That means PvE is loaded during the EPID join process, QE is loaded the first time you request a quote etc.
Architectural enclaves are signed by a special Intel key that is privileged (CPU/microcode checks the signature and only allows enclaves signed with this key to be privileged). Documentation mentions possibility for custom Launch Enclaves (not signed by Intel), but this currently is not possible as far as I know.
