Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1550 Discussions
How to decode the Platform Info Blob (PIB) returned by Intel® SGX IAS
JesusG_Intel
The open-source sgx-decode-pib tool can be used to decode the Platform Info Blob (PIB) string returned by Intel® SGX IAS when performing remote attestation of an Intel® SGX enclave.
The tool is based on the Rust programming language so you must install Rust and run a build script before running the tool.
Note You must also install the Intel® SGX SDK  before building this tool.
 1. Install Rust:
Linux, macOS, or other Unix-like OS
Run the following command in a terminal
 $ curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
Windows
Download and run rustup-init.exe (32-bit) or rustup-init.exe (64-bit)
 2. Download or clone the sgx-decode-pib Github repository:
 $ git clone https://github.com/dingelish/sgx-decode-pib-rs.git
 3. Install dependencies and build the app:
Note
Before building the app, make sure the build.rs file reflects the correct location of your SGX installation. The build.rs file assumes you have installed the Intel® SGX SDK at /opt/intel/sgxsdk. Edit this path in the build.rs file if it is not correct.
For Windows, specify the directory where SGX libraries are located, e.g.
let sdk_dir = env::var("SGX_SDK").unwrap_or_else(|_| "C:\\Program Files (x86)\\Intel\\IntelSGXSDK\\bin\\x64\\Release".to_string());
$ cd sgx-decode-pib-rs-master
$ cargo build
4. Execute the tool:
$ cd target/debug
$ sgx-decode-pib <PIB>
Where <PIB> is the Platform Info Blob returned by IAS. It looks something like this: 00023232392323213012312213213000234941234…
Labels (3)
