Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1540 Discussions
Illegal instruction on sgx_create_ex() for Switchless Library
Jaemin_Park__Jaemin
Dear,
I'm implementing a prototype to use Switchless Library.
A sample code of Switchless in SDK works fine in my machine (NUC8i7HVK) that runs Ubuntu Desktop 16.04.5 (64-bit).
However, my prototype receives SIGILL when the prototype invokes sgx_create_ex().
I followed the sample code of Switchless to implement my prototype.
Unfortunately, I cannot open all about my prototype, but I hope I can get any hint to fix this problem.
o Environment: Intel NUC8i7HVK(running Ubuntu Desktop 16.04.5 (64-bit)), newest linux SGX SDK and SGXSSL
o Makefile (parts of it)
 SGX_COMMON_FLAGS += -Wall -Wextra -Winit-self -Wpointer-arith -Wreturn-type \
                    -Waddress -Wsequence-point -Wformat-security \
                    -Wmissing-include-dirs -Wfloat-equal -Wundef -Wshadow \
                    -Wcast-align -Wcast-qual
SGX_COMMON_CFLAGS := $(SGX_COMMON_FLAGS) -Wjump-misses-init -Wstrict-prototypes -Wunsuffixed-float-constants
###### SGX SSL library #####
USGXSSL_LIBRARY := sgx_usgxssl
USGXSSL_CFLAGS := -fpic -fpie -fstack-protector -Wformat -Wformat-security -Wno-attribute
COMMON_SGXSSL_LINK_FLAGS := -Wl,-z,noexecstack -Wl,-z,relro -Wl,-z,now -pie
URTS_LIB_NAME := sgx_urts
SERVICE_LIB_NAME := sgx_uae_service
CFLAGS += $(SGX_COMMON_CFLAGS) $(USGXSSL_CFLAGS)
CFLAGS += -I$(SGX_SDK)
CFLAGS += -I$(SGX_SDK)/include
LDLIBS += $(SGX_COMMON_CFLAGS) $(COMMON_SGXSSL_LINK_FLAGS)
LDLIBS += -L$(SGX_LIBRARY_PATH) -l$(URTS_LIB_NAME) -lpthread -l$(SERVICE_LIB_NAME)
LDLIBS += -L$(SGXSSL_LIBRARY_PATH) -l$(USGXSSL_LIBRARY)
##### SGX Enclave settings #####
TRTS_LIB_NAME := sgx_trts
TSERVICE_LIB_NAME := sgx_tservice
CRYPTO_LIB_NAME := sgx_tcrypto
TSGXSSL_LIB_NAME := sgx_tsgxssl
TSGXSSL_CRYPTO_LIB_NAME := sgx_tsgxssl_crypto
ENCLAVE_C_SRC := $(wildcard $(ENCLAVE_PATH)/*.c)
ENCLAVE_C_OBJ := $(ENCLAVE_C_SRC:.c=.o)
ENCLAVE_INC := -I. -I$(ENCLAVE_PATH) -I$(SGX_SDK) -I$(SGX_SDK)/include -I$(SGX_SDK)/include/tlibc -I$(SGX_SDK)/include/stlport -I$(SGXSSL_PACKAGE)/include
COMMON_C_CPP_FLAGS := -DOS_ID=1 $(SGX_COMMON_CFLAGS) -nostdinc -fvisibility=hidden -fpic -fpie -fstack-protector -fno-builtin-printf -Wformat -Wformat-security $(ENCLAVE_INC) -include "tsgxsslio.h"
ENCLAVE_C_FLAGS := $(COMMON_C_CPP_FLAGS) -Wno-implicit-function-declaration -std=c11
ENCLAVE_CPP_FLAGS := $(COMMON_C_CPP_FLAGS) -std=c++11 -nostdinc++
TSGXSSL_LINK_FLAGS := -L$(SGXSSL_LIBRARY_PATH) -Wl,--whole-archive -l$(TSGXSSL_LIB_NAME) \
                      -Wl,--no-whole-archive -l$(TSGXSSL_CRYPTO_LIB_NAME)
ENCLAVE_LFLAGS := $(SGX_COMMON_CFLAGS) -Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles \
          -Wl,--whole-archive -lsgx_tswitchless -l$(TRTS_LIB_NAME) -Wl,--no-whole-archive \
          $(COMMON_SGXSSL_LINK_FLAGS) \
          $(TSGXSSL_LINK_FLAGS) \
          $(SGXSSL_LIBRARY) -L$(SGX_LIBRARY_PATH) \
                  -Wl,--start-group -lsgx_tstdc -lsgx_tcxx -l$(CRYPTO_LIB_NAME) -l$(TSERVICE_LIB_NAME) -Wl,--end-group \
                  -Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined \
                  -Wl,-pie,-eenclave_entry -Wl,--export-dynamic \
                  -Wl,--defsym,__ImageBase=0 \
          -Wl,--version-script=$(ENCLAVE_PATH)/enclave.lds
ENCLAVE_NAME := enclave.so
SIGNED_ENCLAVE_NAME := enclave.signed.so
ENCLAVE_CONFIG_FILE := enclave.config.xml
Build_Mode := HW_DEBUG
Park__Seonghyun1
Hi, I am encountering similar issue here.
Simply linking libtsgx_ssl libraries with switchless library causes an error (Illegal instruction)
Did you solve this issue?
Jaemin_Park__Jaemin
Today, I think I figure out this issue.
I referred to this post (https://github.com/intel/linux-sgx/issues/414).
Then, I rebuilt SGX SDK with "make USE_OPT_LIBS=0" and also PSE ("make").
I installed SDK and also PSE, and rebuilt linux-sgx-driver (and also installed it).
Finally, I could create my enclave with switchless.
I hope this can help others.
Jaemin_Park__Jaemin
Today I attempted to use `sgx-gdb` for some debugs.
And then I came back to the previous status, but unfortunately, I faced the same error, illegal instruction, in sgx_create_ex().
Now I'm finding a way to fix it.
Jaemin_Park__Jaemin
Finally, I could figure out my problem.
I re-built SGX-SDK and also PSW with "USE_OPT_LIBS=0" option as follows:
$ cd linux-sgx
$ make USE_OPT_LIBS=0
$ make sdk_install_pkg USE_OPT_LIBS=0
$ make deb_pkg USE_OPT_LIBS=0
Installing the built SDK and PSW and re-building my enclave that leverages Switchless could fix the problem.
Shao__Qifeng
I am encountering similar issue too.
That may be a conflict between switchless libraries and libtsgx_ssl libraries
