Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel SGX EDL File Syntax Question
rkarl
Dear Intel SGX Team,
In the EDL file, when specifying the size of the buffers passed into and out of the enclave, does the size keyword refer to the number of elements in the buffer or the number of bytes in the buffer?
I greatly appreciate any help you can provide.
rkarl
Dr__Greg
Good evening Rkari, I hope this note finds your weekend going well.
The size is the size in bytes of the buffer.  If it were the number of data elements being marshaled into the buffer there would be a need to specify to the EDL code the size of each data element, ala calloc(3).
We will see if this reply conveys a badge for the most concise reply...
Have a good week.
Dr. Greg
Dr__Greg
Have a good week.
Dr. Greg
rkarl
Dear Dr. Greg,
Thank you so much for your help.
I greatly appreciate such a prompt reply, especially over the weekend (definitely badge worthy)!
I hope you have a good week too!
Kind regards,
rkarl
