Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1556 Discussions
Intel SGX, SampleCommonLoader sample code error sgx_enclave_common.h: No such file or directory
donaldi95
I wanted also to ask about an error i get.
It Is because of a library called sgx_enclave_common.h.
When i run the SampleCommonLoader code sample in HW mode, it gives me the following error:
App/sample.cpp:36:10: fatal error: sgx_enclave_common.h: No such file or directory 36 | #include "sgx_enclave_common.h"
Any idea on what should i do?
PS: I am following the SGX tutorial for Linux 20.04. My laptop had I7-8U generation. SGX is enabled, but it doesn't support DCAP.
Best Regards, Donald
JesusG_Intel
Hello Donald,
Copy sgx_enclave_common.h from <sgxsdk>/include/ to <sgxsdk>/SampleCode/SampleCommonLoader/Include/
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Donald,
Sincerely,
Jesus G.
donaldi95
 Hello Jesus G.
I did this and i run into an other error.
GEN => App/sample.o
GEN => App/enclave_entry.o
/usr/local/bin/ld: cannot find -lsgx_enclave_common
collect2: error: ld returned 1 exit status
make: *** [Makefile:35: sample] Error 1
I also did make clean, and when i make again same error.
I did GEN => App/sample.o
i also did again Source {sgxsdk}/environent. And nothing changed.
Donald
JesusG_Intel
Hello Donald,
Check if /usr/lib/x86_64-linux-gnu/libsgx_enclave_common.so exists. If it does not exist, run:
$ sudo ln -s /usr/lib/x86_64-linux-gnu/libsgx_enclave_common.so.1 /usr/lib/x86_64-linux-gnu/libsgx_enclave_common.so
Run make again.
It seems that the SampleCommonLoader sample in the SGX SDK for Linux is buggy. It works fine in Windows.
Please open an issue in https://github.com/intel/linux-sgx/issues detailing these two problems. You will get the attention of the SGX engineering team in Github.
Sincerely,
Jesus G.
donaldi95
Hello Jesus G.
Thank you so much for your help it finally worked. I will report it on their git repo asap.
Donald
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
