Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel SGX, sgx_create_enclave() never returns if called from dllmain()
mingbo_z_1
SGX API works fine if it's called from a process. I can create an enclave successfully.
But when sgx_create_enclave() is called from dllmain(), it never returns. It eventually calls WaitForSingleObject() and wait there.
No matter the dll is injected into a process or load by a process.
uty
Francisco_C_Intel
I believe this is due to:
Dynamic-Link Library Best Practices https://msdn.microsoft.com/en-us/library/windows/desktop/dn633971(v=vs.85).aspx
"You should never perform the following tasks from within DllMain:
*  Call LoadLibrary or LoadLibraryEx (either directly or indirectly). This can cause a deadlock or a crash."
(edited to fix link)
Mingbo_Z_
I installed the latest version of SDK, still got the same problem.
Francisco_C_Intel
Mingbo_Z_
Thanks for the reply and link :)
I know sgx_create_enclave()  will load xxx.signed.dll at some point.   I want use sgx in some processes which I don't have source code. I guess I have to use sgx_create_enclave() lazily (The first time I need to use enclave).
