Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel SGX web applications in linux
Ziidev
I am new to Intel SGX platform and i am not coder, so please explain in lame words. I want to know how we can develop a web application using Intel Sgx. A basic code would also be helpful, like a hello world string posted over the website using SGX ocall. I basically want to know how to connect these two applications. Do we build library and then call them in web apps or there is a direct way to inject sgx code into web.
JesusG_Intel
(I meant to post this in the forum)
Hello Ziidev, we found a workaround that will allow you to install the Intel SGX SDK.
  1. Rename the SGX SDK installer .exe to SGX_installer.zip. Change the extension from .exe to .zip.
  2. Extract the SGX SDK installer .zip
  3. Go to the directory: SGX SDK/installs
  4. Double click on the components you want to install:
    1. SGX_SDK_100.msi
    2. SEWizardVS20xx
    3. SEConfigureVS20xx
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Ziidev,
I will close this case now as there is nothing we can recommend now. Please open a new thread if you encounter further issues.
I wish you the best.
Sincerely,
Jesus G.
