- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
CPUID[07H][EBX][bit 2] reveals that SGX feature is unavailable with the i5-6300U processor I am using, but the specification <http://ark.intel.com/products/88190/Intel-Core-i5-6300U-Processor-3M-Cache-up-to-3_00-GHz> indicates that Intel SGX is available with the processor.
Should I install the evaluation SDK first? I am with Windows 10 Pro now.
CPUID dump
EAX ECX EAX EBX ECX EDX
0 0 15 756e6547 6c65746e 49656e69
1 0 406e3 1100800 fed87383 bfcbfbff
4 0 1c004121 1c0003f 3f 0
4 1 1c004122 1c0003f 3f 0
4 2 1c004143 c0003f 3ff 0
4 3 1c03c163 2c0003f fff 2
4 4 0 0 0 0
5 0 0 0 0 0
6 0 7f3 2 9 0
7 0 0 1c2bbb 0 0
9 0 0 0 0 0
a 0 0 0 0 0
b 0 1 2 100 1
b 1 4 4 201 1
b 2 0 0 2 1
c 0 0 0 0 0
d 0 7 340 340 0
d 1 1 0 0 0
d 2 100 240 0 0
f 0 0 0 0 0
f 1 0 0 0 0
10 0 0 0 0 0
10 1 0 0 0 0
14 0 0 0 0 0
14 1 0 0 0 0
15 0 2 d0 0 0
80000000 0 80000008 0 0 0
80000001 0 0 0 121 28100800
80000002 0 65746e49 2952286c 726f4320 4d542865
80000003 0 35692029 3033362d 43205530 40205550
80000004 0 342e3220 7a484730 0 0
80000006 0 0 0 1006040 0
80000007 0 0 0 0 100
80000008 0 3027 0 0 0
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Please visit you platform manufacturer's website and see if they have a BIOS update for your platform.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jeremy.
Here's an answer quoted from a previously asked similar question:
"Intel® Software Guard Extensions (Intel® SGX) is introduced with all Skylake processors (which includes the i7-6567U). However, it must be noted that at the system-level it relies on OEM/ODM enabling as well as software that takes advantage of it."
This means, you not only need a CPU that supports SGX, but also a platform/BIOS that has been SGX enabled.
Regards.
Scott
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Scott,
I am uncertain the exact cause of unexpected value (clear bit) in the SGX feature bit with CPUID in my case.
Could you elaborate a little bit more the symptom(s) of OEM/ODM enabling/disabling? Does the software refer to the "Intel SGX evaluation SDK" as at this writing? How can one determine if a platform/BIOS has enabled/disabled SGX?
Jeremy
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks Simon. The SGX feature bit (CPUID.07H.EBX.SGX[bit 2]) changed from 0 to 1 after applying December firmware update of Microsoft.
4 4 0 0 0 0
5 0 0 0 0 0
6 0 7f3 2 9 0
7 0 0 1c2bbf 0 0
9 0 0 0 0 0
a 0 0 0 0 0
b 0 1 2 100 1
b 1 4 4 201 1
b 2 0 0 2 1
c 0 0 0 0 0
d 0 7 340 340 0
d 1 1 0 0 0
d 2 100 240 0 0
d 3 0 0 0 0
d 4 0 0 0 0
f 0 0 0 0 0
f 1 0 0 0 0
10 0 0 0 0 0
10 1 0 0 0 0
14 0 0 0 0 0
14 1 0 0 0 0
15 0 2 d0 0 0
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Jeremy, is it a Microsoft Surface you are using?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Fredrik,
Microsoft Surface Pro 4 (freeze, flicker, features missing......). How come you make such a good guess?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Am I detecting any irony there? :)
Firmware update by Microsoft -> the only computers Microsoft provides are the surface models, right?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
So what you have achieved is fixing the processor support for SGX. My internal sources tell me that Surface Pro 4 did not enable SGX in their BIOS (i.e. reserve the memory for SGX use). You will need to confirm this with MSFT.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Simon, thank you for the further reply. My next question is existing zero result of CPUID.0CH (both sgx1 and sgx2 are zero, but Skylake should support sgx1). I can save it now. I'll try to obtain confirmation from Microsoft Surface support...
Fredrik, I am not aware that Surface is the only computer sold by Microsoft. Thanks for teaching.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I think you meant to say CPUID.12H not CPUID.0CH
Section 37.7.2 of the Software Developer Manual states "A properly configured processor exposes Intel SGX functionality with CPUID.EAX=12H reporting valid information (non-zero content) in three or more sub-leaves, see Table 37-4."
What this means is that once the BIOS has completed the necessary configuration this CPUID leaf is available. All zeros returned in EAX means that your BIOS is probably not configured to support SGX.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
