Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel TSX and SGX are not working together
JWChang
I am trying to use Intel TSX (RTM) 'xbegin' and 'xend' instruction in the SGX Enclave.
But, whenever I tried, it always goes to 'abort' region.
Does the TSX Instructions no longer available in the SGX Enclave?
If the Micro-code is patched to not allow TSX instructions, is there any way to downgrade the micro-code patch or sth?
AlHill
What processor do you have?
JWChang
I use Intel(R) Core(TM) i5-8500 CPU @ 3.00GHz
JesusG_Intel
amy-zhang
It seems that  Intel TSX would abort inside the enclave in the hyperthreading-enabled processor.  Is this statement correct?
Another question is: will Intel enable TSX inside the enclave in the future?
Thanks a lot!
amy-zhang
It seems that  Intel TSX would abort inside the enclave in the hyperthreading-enabled processor due to the TAA vulnerability.  Is this statement correct?
Thanks a lot!
JesusG_Intel
Hello amy-zhang,
I don't know enough about Intel TSX, TAA, and HT to answer your question. Please try asking your question in the Processors Community.
Regarding your second question, we cannot comment on future roadmaps.
Jesus G.
Intel Customer Support
JesusG_Intel
Intel is no longer monitoring this thread. If you want a response from Intel in a follow-up question, please open a new thread.
