Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Is SGX enabled on my Surface 4 pro?
Sam5
How can I know if my recently bought MS Surface pro with I5 Skylake processor has SGX enabled or not?
-Thanks
Surenthar_S_Intel
I cannot recommend you a specific models and manufacturers of laptops. Some product lines maintain the same name from year to year, and it’s just the CPU model that changes, while other products let you customize the CPU options so you could start with something that is SGX-compatible and customize it with a CPU that isn’t.
The best advice I can give: don’t buy a system unless you can review its technical specs and see either:
  • A 6000-series model number (i3-6xxx, i5-6xxx, or i7-6xxx), or The phrase “Intel® 6th generation CoreTM processor”
  • All 6th generation Intel processors support SGX. Before you purchase kindly refer to Intel ARK website(http://ark.intel.com/) for the list of processors that supports SGX and also make sure to check with OEM to provide drivers and firmware to support SGX
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Actually there is a list of capable hardware maintained at https://github.com/ayeks/SGX-hardware, you can refer to it.
Sam5
Thanks for your detailed Information.
And also i look one forum from IDZ(https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/627992ThinkPad laptops have SGX enable.
