Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1543 Discussions
Issues with PCCS Setup and MAA Attestation for Secure Key Release POC
vinothacc2019
Hello everyone,
I am working on a POC to securely expose keys from Azure Key Vault Managed HSM. However, I have encountered several challenges along the way and would appreciate any guidance or advice.
Environment and Setup Details:
  • PCCS Service:
    • The latest PCCS code seems to be missing from the Intel repository.
    • I used older code to set up the PCCS service, but I am unsure if it is configured correctly for my use case.
  • Development Mode:
    • I am using a single-step signing process in debug mode for this POC.
    • Report and quote generation succeed, but issues arise during attestation with Microsoft Azure Attestation (MAA) service.
Problem Description:
While sending the generated quote to the MAA service, I encounter the following error:
Error Logs:
[13:51:06.449] : Exception occurred during MAA call: Attestation Enclave operation failed with 65534: SuppliedRuntimeDataDigest does not match RuntimeData Digest in quote: 'The specified quote was invalid due to an error in the quote collateral.'
  • Key Error Points:
    • InvalidParameter: SuppliedRuntimeDataDigest does not match RuntimeData Digest in quote.
    • Quote validation fails due to mismatches in runtime data digest.
    • The error occurs when using the validatequotes.core sample from the Azure SGX repository.
Request for Help:
I would appreciate assistance with the following:
  1. Correct Steps for PCCS Setup:
    • Are there updated resources or repositories for setting up PCCS service correctly for both development and production environments?
    • Is it recommended to continue with the older PCCS code, or should I adopt a different approach?
  2. MAA Service Integration:
    • How can I resolve the runtime data digest mismatch issue during attestation?
    • Are there best practices for correctly signing and verifying quotes with the MAA service?
I am following the SKR documentation from Microsoft: Secure Key Release Documentation.
Any insights or guidance on how to complete this POC successfully for both dev and prod environments would be greatly appreciated.
Thank you in advance!
Vinothkumar S
