Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Key Derivation - MK, SK, VK, SMK
Joe63
Hey,
does anyone know what these multiple key in the RemoteAttestation SampelCode are used for?
What does SK, VK, MK and SMK mean? Does SK stand for Storage-Key or Signing-Key? What are the use, cases for all of that 4 key-types? In dont find online any detailed information!
Thanks!
Surenthar_S_Intel
  • SK (Signing Key/Symmetric Key)
  • MK (Master Key/Masking Key)
  • SMK (SIGMA protocol)
  • ISV can use the sgx_ra_init_ex API to provide a callback function to generate the remote attestation keys used in the SIGMA protocol (SMK) and returned by the API sgx_ra_get_keys (SK, MK, and VK). The decision to use a different KDF is a policy of the ISV, but it should be approved by the ISV’s security process.
  • sgx_ ra_derive_secret_keys_t function takes the Diffie-Hellman shared secret as input to allow the ISV enclave to generate their own derived shared keys (SMK, SK, MK and VK).
  • Remote Attestation context was generated by sgx_ra_init, the returned SGX_RA_ KEY_MK, SGX_RA_KEY_SK or SGX_RA_VK is derived from the Diffie-Hellman shared secret elliptic curve field element between the service provider and the application enclave using the following Key Derivation Function (KDF):
    • KDK = AES-CMAC(key0, gab x-coordinate)
    • SGX_RA_KEY_VK = AES-CMAC(KDK, 0x01||’VK’||0x00||0x80||0x00)
    • SGX_RA_KEY_MK = AES-CMAC(KDK, 0x01||’MK’||0x00||0x80||0x00)
    • SGX_RA_KEY_SK = AES-CMAC(KDK, 0x01||’SK’||0x00||0x80||0x00)
  • The key0 used in the key extraction operation is 16 bytes of 0x00. The plain text used in the Key derivation calculation is the Diffie-Hellman shared secret elliptic curve field element in Little Endian format.
  • The plain text used in each key calculation includes:
    • a counter (0x01)
    • a label: the ASCII representation of one of the strings 'VK', 'MK' or 'SK' in Little Endian format
    • a bit length (0x80)
-Surenthar
Joe63
Okay thanks, for that information.
I have another question. I saw the RemoteAttestation example. If i wanna communicate over the secure communication channel (established in the Remot-Attestation process), should i therefor use the SK-Key to sign the data? The background is: i wanna communicate information after the result-message (sent from SP to Enclave), back from the enclave to the SP. The Enclave has received a so called secret from the SP (which is in the result message). As i see it the message was only to demonstrate, that i can protect information with the sk-key right? So if i wanna send a message back to the SP afterward, there are no advantages to put the secret in that message, right? My message has only a payload field and a MAC-field (mac over payload with sk-key). i dont wanna encrypt my payload but i wanna ensure i is from the enclave, so am i processing right?
Surenthar_S_Intel
Please refer the link for more info about remote attestation https://software.intel.com/en-us/articles/intel-software-guard-extensions-remote-attestation-end-to-end-example
-Surenthar
Adrian_D_
you explained what SK, MK and SMK stand for, but left out VK. What does VK mean?
Anusha_K_Intel
  • VK: Verification key
  •  VK is derived  from the Diffie-Hellman shared secret elliptic curve field element between the service provider and  the application enclave.
  • VK  = AES-CMAC (0x00, gab  x coordinate|| 0x03)
