Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Research with modifying TDX's quoting enclave
gloryh
I'm working as a researcher at NYU.
I'd like to directly modify some codes of Intel TDX's quoting enclave and get a sign on the custom quoting enclave from the Intel Attestation service for my research.
Can you share with me how to get a signed custom quote?
Is it forbidden to get Intel's sign on the modified quoting enclave?
Sincerely,
Labels (2)
Scott_R_Intel
Hello.
You can of course change the QE to sign quotes however you want and then sign the QE yourself.  But, Intel cannot/will not production sign any modified QE.
Regards.
gloryh
Thanks for your response.
Now I'm trying to modify the TDQE for remote attestation tests.
However, it seems that two GitHub repos are being maintained for the TDQE source code for Intel TDX.
https://github.com/intel/SGXDataCenterAttestationPrimitives
https://github.com/intel/linux-sgx
Could you provide some guidelines to modify the TDQE in the QGS of TDX.
Also, I'd like to make a custom TDQE and run it on the QGS of TDX.
In the instructions for Linux's TDX installation, it only explained how to install the prebuilt binaries, but there is no guidance on modifying the custom TDQE and building the QGS binary with the custom TDQE.
https://github.com/canonical/tdx/blob/main/attestation/setup-attestation-host.sh
Many thanks.
Scott_R_Intel
Hello again.
The tdqe source can be found underneath the first link you provided, here.  After installing the build pre-reqs for building the tdqe, I was able to enter the enclave/linux folder and simply "make" to create a "tdqe.so".
So, steps you could follow:
  1. Modify that source to your need.
  2. Build it ("make") to create tdqe.so.
  3. Create a signing key.
  4. Sign the enclave.
  5. Replace the real tdqe (after backing up) usually in "/usr/lib/x86_64-linux-gnu/"
  6. Restart the QGS service to start using your custom QE.
Just an FYI, the QE in your first link there is the old SGX EPID based QE (no longer supported).  And also, there is an SGX QE called the "QE3" that is located here.
Regards.
gloryh
By the way, the Intel-signed quoting enclave is typically signed from the provisioning certification enclave with PCK.
Are there any signing key generation methods to sign the custom QE, and is it possible to directly run the quoting enclave that is signed by non-PCK with QGS?
Also, do I need to generate another certificate, as the certificate of Intel PCS, for the new signing key?
Many thanks.
Scott_R_Intel
Hi again.
I think there's some confusion here about the PCE's role.  It doesn't actually sign the QE enclave binary, which is what I was referring to in my previous reply.  To sign your own enclave, you'd need to simply create a key with openssl and sign the enclave with that key using the sign_tool included with the Intel SGX SDK.  All of the SGX SDK samples use this simple method of creating a key and signing the resulting enclave binary, such as seen here.
What the PCE does is certify the QE generated attestation key that comes in a request from the QE, as talked about in this whitepaper.   The PCE is what is truly rooted to the CPU hardware.
