Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Running in an enclave based on Intel SGX
jet_li_ofchina
The program running in an enclave based on Intel SGX—the process of data intersection between parties A and B—does it have a solution where data can be output in plaintext to the log? Based on the ccoo case, the cross_lang_framework case, the data running in the program can be output in plaintext to the console. In this way, if the SGX environment is on A's machine, can A output the data obtained from B outside the enclave?
Benny_Intel
unfortunately, I cannot understand the question and thus cannot provide an answer.
If this question is related to the Confidential Computing Zoo project, please use support mechanism provided by the project.
Benny
