Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX Plugin for Eclipse not working
Svart_K_
I have tried to install the SGX Plugin in Eclipse following this instructions
https://download.01.org/intel-sgx/linux-1.6/docs/Intel_SGX_SDK_Installation_Guide_Linux_1.6_Open_Source.pdf
I have installed Eclipse Mars 4.5.2, and the PDE Plugin. Then I have build the SGX Plugin in the /opt/linux-sgx-master/Linux_SGXEclipsePlugin/ folder successfully. But when going into Eclipse -> Install New Software -> Add the .zip -> select SGX Eclipse Plugin (1.6.100.1) and then click on next, Eclipse does not continue but simply just keeps showing the loading icon!?
Have I missed something in the instructions?
Thanks for any help
Surenthar_S_Intel
Svart_K_
Thank you for the reply.
I have followed the instructions:
Which now, when selecting the archive in Eclipse, shows the SGX plugin version 1.6.100.v
Unfortunately when clicking the 'Next' button I still experience the same issue, that the Eclipse keeps loading without proceeding.
I don't see any error messages in the terminal. Is there another way to include the .zip archive or at least to debug the problem somehow?
Thank you
bohn__christian
I am trying to install the SGX plugin for Eclipse Oxygen, but the installation failed. The error message says that 'org.eclipse.cdt.ui' is required but could not be found. I have followed all the steps in the instructions, so what am I doing wrong here?
Thanks for any help.
