Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX SDK version 2.9 Support in RHEL 7.6
Anandakumar
New Contributor II
As mentioned in the installation document, If no SDK installers provided for the SGX SDK 2.9 and above, for the below OS distribution
Anandakumar_0-1626157051818.pngShould I use SGXSDK 2.8 instead SGXSDK 2.9 ? If SDK is not supported, then why those distributions are in the supported OS list?
Anand
JesusG_Intel
Hello Anand,
The long list of supported OSes includes support for the SGX driver and PSW. The SDK installer is more restrictive because of the native GCC version in the unsupported OSes.
Since this is security software, you should use the latest released software to ensure you have the most up-to-date security and functionality fixes. Using older SDKs makes your software less secure. We recommend to upgrade your OS so that you can use the latest version of the SGX SDK.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Anand,
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
