Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
TCSNUM value for Production setup
Anandakumar
New Contributor II
Hi Team,
related thread : https://community.intel.com/t5/Intel-Software-Guard-Extensions/Thread-handling-in-SGX/td-p/1292867/jump-to/first-unread-message
We have hosted a Java Application backed by Intel SGX to perform some secure operation.
The Java App's maxThreadNum set to 150 threads and the server has 8 cores(Xeon E2288G). Here, Can I set TCSNUM to 150 to support the max threads from Java?
Anand
JesusG_Intel
Hello Anand,
I have not seen a spec for the maximum number of TCS_NUM so I think it should work. I recommend trying TCS_NUM = 150 and evaluate the results.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Anand,
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
