Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX SSL Library
bohn__christian
bohn__christian
I want to set up an SSL connection within an SGX enclave. I looked at the Developer Guide for the Intel SGX SSL Library, but I am wondering  if the library supports only the cryptographic functions referenced in the appendix, or if it also contains the functions of the part of OpenSSL that allows to create SSL connections.
Hoang_N_Intel
There is no question in the posting but I assume that you are looking for the SSL library to be used with Intel SGX. You can take a look at this previous posting to see whether this option of using wolfSSL library can meet your development requirement or not: https://software.intel.com/en-us/forums/intel-software-guard-extensions-intel-sgx/topic/746997
