Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX and SGX1 of CPUID with SKL emulation
JWong19
I am confused by CPUID data (see below) of SKL emulation with the latest version (7.39-win) of Intel SDE.
CPUID.07H.EBX.SGX[bit 2] = 0, but, CPUID.12H.EAX.SGX1[bit 0] = 1. How should I understand this?
       0   0       12 756e6547 6c65746e 49656e69 GenuineIntel
       1   0    406e0   100800 7ffaf3ff bfebfbff 06_4EH +SSE3 +PCLMULQDQ +MONITOR +VMX +SMX +EIST +TM2 +SSSE3 +FMA +CMPXCHG16B +PDCM +SSE4.1 +SSE4.2 +x2APIC +MOVBE +POPCNT +TSC-Deadline +AES +XSAVE +OSXSAVE +AVX +F16C +RDRAND +FPU +VME +DE +PSE +TSC +MSR +PAE +MCE +CX8 +APIC +SEP +MTRR +PGE +MCA +CMOV +PAT +PSE36 -PSN +CLFSH +DS +ACPI +MMX +FXSR +SSE +SSE2 +SS +HTT +TM +PBE
       2   0 76035A01   F0B6FF        0   C10000
       3   0        0        0        0        0
       4   0 1C004121  1C0003F       3F        0 D-Cache L1  2processor(s)  8core(s)  8way(s) * 1partition(s) * 64B *    64set(s)
       4   1 1C004122  1C0003F       3F        0 I-Cache L1  2processor(s)  8core(s)  8way(s) * 1partition(s) * 64B *    64set(s)
       4   2 1C004143   C0003F      1FF        0 U-Cache L2  2processor(s)  8core(s)  4way(s) * 1partition(s) * 64B *   512set(s)
       4   3 1C03C163  3C0003F      7FF        6 U-Cache L3 16processor(s)  8core(s) 16way(s) * 1partition(s) * 64B *  2048set(s)
       5   0       40       40        3    42120 [64B,64B] +MWAIT +InterruptsAsBreakEvent C0/0 C1/2 C2/1 C3/2 C4/4 C5/0 C6/0 C7/0
       6   0       77        2        1        0 +ThermalSensor +TurboBoost +ARAT +PLN +ECMD +PTM -HWP -HDC -SETBH
       7   0        0   1C67A9        0        0 +FSGSBASE -IA32_TSC_ADJUST -SGX +BMI1 -HLE +AVX2 -FDP_EXCPTN_ONLY +SMEP +BMI2 +FastString +INVPCID -RTM -PQM +SuppressFCS +SuppressFDS +MPX -PQE -AVX512F -AVX512DQ +RDSEED +ADX +SMAP -AVX512IFMA -PCOMMIT -CLFLUSHOPT -CLWB -PT -AVX512PF -AVX512ER -AVX512CD -SHA -AVX512BW -AVX512VL -PREFTEHCHWT1 -AVX512VBMI -PKU -OSPKE
       8   0        0        0        0        0
       9   0        0        0        0        0
       A   0  7300403        0        0      603 Version-ID=3 4*48b +CoreCycleEvent +InstructionRetiredEvent +ReferenceCyclesEvent +LLC_ReferenceEvent +LLC_MissesEvent +BranchInstructionRetiredEvent +BranchMispredictRetiredEvent 3*48b
       B   0        1        2      100        0     SMT x2APIC-ID=0 Topology-ID=0 Logical-Processor=2
       B   1        4        2      201        0    Core x2APIC-ID=0 Topology-ID=0 Logical-Processor=2
       C   0        0        0        0        0
       D   0       1F      440      440        0 +x87 +SSE +AVX +BNDREGS +BNDCSR -Opmask -ZMM_Hi256 -Hi16_ZMM -PT -PKRU 1088B 1088B
       D   1        F      240      100        0 +XSAVEOPT +Compaction_Extensions +XGETBV +XSAVES_IA32_XSS 576B
       D   2      100      240        0        0 AVX        256B @  576B
       D   3       40      3C0        0        0 BNGREG      64B @  960B
       D   4       40      400        0        0 BNGCSR      64B @ 1024B
       E   0        7      340      340        0
       F   0        7      340      340        0
       F   1        1        0        0        0
       F   2      100      240        0        0
      10   0        7      340      340        0
      10   1        1        0        0        0
      11   0        7      340      340        0
      12   0        1        0        0        0 +SGX1 -SGX2
80000000   0 80000008        0        0        0
80000001   0        0        0      121 2C100000 +LZCNT +PREFTEHCHW +ExecuteDisable +1GBytePages +RDTSCP +x64
80000002   0        0        0        0        0
80000003   0        0        0        0        0
80000004   0        0        0        0        0
80000005   0        0        0        0        0
80000006   0        0        0  1006040        0 64B 8-way 256KB
80000007   0        0        0        0      100 +InvariantTSC
80000008   0     3028        0        0        0 40b 48b
MarkC_Intel
Intel SDE does not support SGX. The leaf 12 values are not meaningful data in the released version of SDE.
MarkC_Intel
JWong19
Thanks for your reply. According to CPUID description of the instruction set reference document,
If a value entered for CPUID.EAX is less than or equal to the maximum input value and the leaf is not supported on
that processor then 0 is returned in all the registers.
MarkC_Intel
Consider the bug report filed... Thx.
