Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX in virtualized environment
Svart_K_
Is it possible to start and run enclaves from within a virtualized environment such as VirtualBox or Docker?
Rodolfo_S_
New Contributor III
Hi, Svart.
It is possible to run and start enclaves from virtual machines. However, the virtualization software must be able to support the SGX instruction set. AFAIK VirtualBox and Docker still don't support SGX, but KVM and Xen both have patches available to support SGX.
For more details see here: https://01.org/intel-software-guard-extensions/sgx-virtualization
Rodolfo
Svart_K_
Hi Rodolfo,
Thanks for the link.
I can understand that VirtualBox does not work since the instruction set is not supported, but shouldn't Docker still work? Since it's lightweight containers are still accessing the hardware from the "real" system they are running on and not simulating any of that?
Rodolfo_S_
New Contributor III
Hi, Svart.
The incompatibility with Docker is actually because Intel runs the SGX PSW aesm as a daemon and not as a regular process. This is not allowed inside Docker containers. There are some patches (attached) written by sean-jc that make SGX compatible with Docker containers, but they are not compatible with the SGX 1.7 commit (current version of Linux SGX).
The following commits are known by me to work with these patches, and I have successfully launched/executed enclaves inside Docker containers by using them:
PSW + SDK: https://github.com/01org/linux-sgx/commit/f4005be591a82b1bedfbf8021cec8929a3911bb1
Driver: https://github.com/01org/linux-sgx-driver/commit/d2d50c36f62693ba629bd1efe4076a1a1f7a06d7
Rodolfo
Svart_K_
Thanks for the clarification
pascal_f_
We have run into the same issue trying to run SGX with Docker containers and I was wondering if there has been some progress to support the latest version of Linux SGX (1.7), or if we should use the previous version. Thanks!
Pascal
Michalevsky__Yan
It's possible to run enclaves within Docker. It however needs configuring access to the PSW AESM service and exposing the SGX driver to the container. But aside from that, we're successfully running SGX applications in Docker containers.
Johnston-Watt__Dunca
Yan
Is this documented anywhere? Many thanks
