Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX inside a VM
NDei
I am trying to use SGX inside an Ubuntu 20.04 VM created with either VMWare Workstation 16 Player or Oracle VM Virtualbox (I tried both).
My Host System has Intel i5-8400T CPU, which according to its documentation supports SGX with Intel ME.
The installed VMs do not support SGX, with the error message being that the CPU does not support it.
When I run $cpuid | grep -i sgx in a terminal the result is
I would appreciate any hints or solutions.
Labels (3)
Anandakumar
New Contributor II
Hi NDei,
Just sharing my experience with SGX VMs here.
With QEMU 6.2.0 and kernel 5.13* I was able to launch enclaves. Since you have been working in Ubuntu, you can give a try with QEMU.
Anand
Sahira_Intel
Make sure SGX is set to enabled or software controlled in the BIOS of the host system. Also make sure you are running Linux kernel 5.13 or later on both the host and  VM.
See more information here: https://www.intel.com/content/www/us/en/developer/articles/technical/virtualizing-intel-software-guard-extensions-with-kvm-and-qemu.html
Sahira_Intel
Hi Anand,
The document cannot be updated yet because there's a libvirt patch we are waiting to be upstreamed before we can correct the document.
Your error about sgx1/2= false is likely to do with SGX being disabled in the BIOS. Did you switch SGX to enabled or software controlled?
Note that a processor that supports SGX with Intel Management Engine only, will not support it on the M10JNP2S board.
Sincerely,
Sahira
Anandakumar
New Contributor II
@Sahira_Intel
Is there any issue link to track the update?
I hope you are referring this to @NDei .
Sahira_Intel
Yes, that comment was meant to be a reply to the original post.
link to track libvirt issue: https://www.spinics.net/linux/fedora/libvir/msg231287.html
Sahira_Intel
Hi @NDei
Let me know if you have more questions.
Sincerely,
Sahira
