Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX newbee
Pratikkuma_P_Intel
I copied the SampleEnaclave application (entire code) with different name so that i can start making changes to it, but if i run this new app then i get following error.
"Error: Invalid enclave metadata."
How do i debug this? and what could be the issue here?
Hoang_N_Intel
SGX_ERROR_INVALID_METADATA means that the "The metadata embedded within the enclave image is corrupt or missing."
If you have renamed the project, maybe you should check this line of code to see whether it matches the new name:
# define ENCLAVE_FILENAME "Enclave.signed.dll"
Check the DLL for its size to see whether the DLL has the same size of the original.
Finally, check the working directory to make sure it points to the right directory where the DLL should reside in.
