Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
Test Intel Attestation Service has incorrect certificate
Rosłaniec__Piotr
Hello.
I just noticed that the certificate on https://test-as.sgx.trustedservices.intel.com domain is incorrect. It's issued for CN "dev-as.sgx.trustedservices.intel.com". The latter is also inaccessible.
Piotr
Elephant
I noticed this too!
Please fix this ASAP.  Thanks!
* Server certificate:
* 	 subject: C=US; postalCode=95054-1537; ST=California; L=Santa Clara; street=FM1-110; street=2200 Mission College Blvd; O=Intel Corporation; OU=Hosted by Intel Corporation; OU=Multi-Domain SSL; CN=dev-as.sgx.trustedservices.intel.com
* 	 start date: Jun  7 00:00:00 2019 GMT
* 	 expire date: Jun  6 23:59:59 2021 GMT
* 	 subjectAltName does not match test-as.sgx.trustedservices.intel.com
shi__webb
I'm calling the `get_sigrl_from_intel`  and it return the following error:
get_sigrl_from_intel tls.read_to_end: Custom { kind: InvalidData, error: WebPKIError(CertNotValidForName) }
Rosłaniec__Piotr
Turns out that the V2 attestation service has reached its end of life. You can learn about the new IAS below:
https://api.portal.trustedservices.intel.com/
https://api.trustedservices.intel.com/documents/sgx-attestation-api-spec.pdf
Update:
I'm not sure about the EOL, but the test IAS seems to have correct certificate now.
