Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Testing Remote Attestation with curl
jgnoonan
I am trying to test remote attestation using curl.  I've generated a quote.dat but when I run the below command, I get the following results:
curl -X POST "https://api.trustedservices.intel.com/sgx/attestation/v4/report" -H "Ocp-Apim-Subscription-Key: <my primary key>" -H "Content-Type: application/json" --data-binary "@quote.dat"
{ "statusCode": 401, "message": "Access denied due to invalid subscription key. Make sure to provide a valid key for an active subscription."
I have subscribed to the following services on my Intel account:
Product Intel® Software Guard Extensions Provisioning Certification Service
Product DEV Intel® Software Guard Extensions Attestation Service (Linkable) subscription
Product Intel® Software Guard Extensions Registration Service subscription
I am using the Primary key from the second service on this list.  What am I doing wrong?
Labels (3)
Scott_R_Intel
Hello.
Per the latest IAS documentation, to use the DEV environment, you must use the https://api.trustedservices.intel.com/sgx/dev base url, and also API version 5 is available.  For example:  https://api.trustedservices.intel.com/sgx/dev/attestation/v5/report
Regards.
jgnoonan
@Scott_R_Intel  Thank you so much for the quick response!  That worked perfectly!
