Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Use GMP,PBC library in Enclave
Li__Xiaoguo
GMP, PBC library includes many cryptographic primitives. But How to use the libraries in the enclave.
I tried https://github.com/intel/sgx-gmp.git to install the gmp library. However, it reports error:
/opt/gmp/6.1.2/include/sgx_tgmp.h:474:12: error: ‘std::FILE’ has not been declared
474 | using std::FILE;
I observed that in the git  https://github.com/intel/sgx-gmp.git , there is a mini-gmp. Is it available?
Thanks very much!
Martin LI
Singapore Management University
Sahira_Intel
Hi Martin,
Which installation step are you getting this error at? Please send over the command you ran.
Also, mini-gmp is part of GNU-MP library
Sincerely,
Sahira
rao2357
I also found this issue, please how to fix it?
Thanks very much!
Ruijun Rao
