Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Using the regular expression library in SGX
Ko__Ronny
I am trying to use regular expressions in my SGX app and in SGX v2.5 I can include the regex header file by doing "#include <regex>". However, I cannot compile the program that looks like the following:
int main()
    string a = "GeeksForGeeks";
    // Here b is an object of regex (regular expression)
    regex b("(Geek)(.*)"); // Geeks followed by any character
    // regex_match function matches string a against regex b
    if ( regex_match(a, b) )
        cout << "String 'a' matches regular expression 'b' \n";
    // regex_match function for matching a range in string
    // against regex b
    if ( regex_match(a.begin(), a.end(), b) )
        cout << "String 'a' matches with regular expression "
                "'b' in the range from 0 to string end\n";
    return 0;
The compiler says regex is not defined. I wonder if regex is not being supported in SGX, yet.
Ronny
