Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Vtune profiling support in SGX enclave
wei__changzheng
I noticed that there is a piece of code of function __create_enclave in psw (urts/urts_com.h), so what is the propose of this code below? Is it helpful for vtune profiling in sgx enclave? How can I enable the isVTuneProfiling flag?
    __itt_init_ittlib(NULL, __itt_group_none);
    bool isVTuneProfiling;
    if(__itt_get_ittapi_global()->api_initialized && __itt_get_ittapi_global()->lib)
        isVTuneProfiling = true;
    else
        isVTuneProfiling = false;
    bool is_SGX_DBG_OPTIN_set = false;
    is_SGX_DBG_OPTIN_set = is_SGX_DBG_OPTIN_variable_set();
    if (isVTuneProfiling || is_SGX_DBG_OPTIN_set)
        SE_TRACE(SE_TRACE_DEBUG, "VTune is profiling or SGX_DBG_OPTIN is set\n");
        bool thread_updated;
        thread_updated = enclave->update_debug_flag(1);
        if(thread_updated == false)
            SE_TRACE(SE_TRACE_DEBUG, "Failed to update debug OPTIN bit\n");
        else
            SE_TRACE(SE_TRACE_DEBUG, "Updated debug OPTIN bit\n");
        if (isVTuneProfiling)
            uint64_t enclave_start_addr;
            uint64_t enclave_end_addr;
            const char* enclave_path;
            enclave_start_addr = (uint64_t) loader.get_start_addr();
            enclave_end_addr = enclave_start_addr + (uint64_t) metadata->enclave_size -1;
            SE_TRACE(SE_TRACE_DEBUG, "Invoking VTune's module mapping API __itt_module_load \n");
            SE_TRACE(SE_TRACE_DEBUG, "Enclave_start_addr==0x%llx\n", enclave_start_addr);
            SE_TRACE(SE_TRACE_DEBUG, "Enclave_end_addr==0x%llx\n", enclave_end_addr);
            enclave_path = (const char*)file.name;
            SE_TRACE(SE_TRACE_DEBUG, "Enclave_path==%s\n",  enclave_path);
            __itt_module_load((void*)enclave_start_addr, (void*) enclave_end_addr, enclave_path);
Francisco_C_Intel
[edit for phrasing/clarity]
The implementation in the SGX URTS to enable VTune to profile enclaves is what you copy+pasted.
Page 20 of https://01.org/sites/default/files/documentation/intel_sgx_sdk_developer_reference_for_linux_os_pdf.pdf has more info on how to profile enclaves using VTune.
Francisco
