Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
What configuration can cause error when resolving libcxx dependencies?
l_r
I have started to work on an already existing SGX Application, with an already existing Makefile, that is for 90% the same as the one in the CXX11SGXDemo, but of course has some modifications (Important ones below).
I wanted to use some standard c++ classes (like vector), and I can compile the small snippets that I wrote when I include them in the CXX11SGX Demo, but In this project, the linker gives the error
/usr/bin/ld: Udfs/extended-data-types.o: in function `std::__1::vector<row_t, std::__1::allocator<row_t> >::allocate(unsigned long)':
/home/leonhard/sgx/sdk/sgxsdk/include/libcxx/vector:930: undefined reference to `std::__1::__vector_base_common<true>::__throw_length_error() const'
/usr/bin/ld: Udfs/extended-data-types.o: in function `std::__1::allocator<row_t>::allocate(unsigned long, void const*)':
/home/leonhard/sgx/sdk/sgxsdk/include/libcxx/memory:1740: undefined reference to `std::bad_alloc::bad_alloc()'
Which is what I get when I try to include the line
auto* rows = new std::vector<row_t>(underlying->tuples, underlying->tuples + underlying->num_tuples * sizeof(row_t));
Other small snippets in the similar spirit cause similar errors, all in relation to exceptions from <new> or <stdexcept>
The biggest difference in the makefile are (probably) the link flags:
Enclave_Link_Flags := $(Enclave_Security_Link_Flags) \
-Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles -L$(SGX_TRUSTED_LIBRARY_PATH) \
-Wl,--whole-archive -l$(Trts_Library_Name) -Wl,--no-whole-archive \
-Wl,--whole-archive -lsgx_tcmalloc -Wl,--no-whole-archive \
-Wl,--start-group -lsgx_tstdc -lsgx_tcxx -lsgx_omp -lsgx_pthread -lsgx_tkey_exchange -l$(Crypto_Library_Name) \
-l$(Service_Library_Name) -Wl,--end-group \
-Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined \
-Wl,-pie,-eenclave_entry -Wl,--export-dynamic \
-Wl,--defsym,__ImageBase=0 -Wl,--gc-sections \
-Wl,--version-script=Enclave/Enclave.lds
 Is there anything that has to be configured differently?
JesusG_Intel
Hello l_r,
How closely are you following the Cxx11SGXDemo?
To help us troubleshoot, send your full Makefile.
Did you remember to source the sgxsdk/environment file?
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello l_r,
Do you still need help with this issue?
You should follow Cxx11SGXDemo as closely as possible.
Sincerely,
Jesus G.
JesusG_Intel
Hello l_r,
We have not heard from you in several days so we will no longer monitor this thread. We hope you were able to resolve your issue. Please start a new thread if you need further help.
Intel is no longer monitoring this thread. If you want a response from Intel in a follow-up question, please open a new thread.
