Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
What is the key format used by sgx_rsa3072_sign ?
you_w_
New Contributor III
Hi everyone:
I want to use the function sgx_rsa3072_sign and sgx_rsa3072_verify in my enclave, but how can I get a rsa key for these functions ?
I see the that key is defined as:
typedef struct _sgx_rsa3072_private_key_t
    uint8_t mod[SGX_RSA3072_KEY_SIZE];
    uint8_t exp[SGX_RSA3072_PRI_EXP_SIZE];
} sgx_rsa3072_private_key_t;
, but typically a rsa key seems like this:
RSAPrivateKey ::= SEQUENCE {
  version           Version,
  modulus           INTEGER,  -- n
  publicExponent    INTEGER,  -- e
  privateExponent   INTEGER,  -- d
  prime1            INTEGER,  -- p
  prime2            INTEGER,  -- q
  exponent1         INTEGER,  -- d mod (p-1)
  exponent2         INTEGER,  -- d mod (q-1)
  coefficient       INTEGER,  -- (inverse of q) mod p
  otherPrimeInfos   OtherPrimeInfos OPTIONAL
So I'm a little confused about this, any one who can tell me how to get a key that satisfied the request of
sgx_rsa3072_private_key_t,
thanks!
you
Anusha_K_Intel
You can use openssl to Generate a 3072-bit RSA private key. Use the following command:
 openssl genrsa -out private_key.pem -3 3072
And more information is given in page 20 here
you_w_
New Contributor III
Hi Anusha K:
Thanks. But I find that the length of modulus & privateExponent do not mach.
mod: 385
EXP: 384
So how can I use it ?
Kind regards
you
you_w_
New Contributor III
Hi  Anusha
I find that the beginning Byte of mod is always 0x00, So is that means that I can use it from the second Byte?
Thank you!
you
