Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Where to find topenssl or X509Verifier project
Fan_S_Intel
I need to use openssl in the enclave, and it is said that there would be a X509Verifier project in src folder with trusted openssl, but I can't find it in the current SDK folder on Windows. How can I get the sample code or is it recommended not to use this library directly in the newest version of sgx on Windows?
Huorong_L_
AFAIK, the X509Verifier project is provided in SDK 1.6.
SDK 1.7 does NOT provide it.
Fan_S_Intel
Then how can I find SGX1.6 SDK resources now? I can only find 1.7 on the net.
Surenthar_S_Intel
Please download the Intel SGX version 1.6 and install on your machine. after installation you will find the source of X509Verifier project under "C:\Program Files (x86)\Intel\IntelSGXSDK\src\X509Verifier"
Go to the link https://software.intel.com/en-us/sgx-sdk and click the download option. download the previous version of SDK instead of latest one(you will able to see the previous version as below the page)
-Surenthar
Juan_d_Intel
If you're working with the Windows 1.7 SDK, my recommendation is that you use the SGX SSL Add-on instead, which is available at the download page: https://software.intel.com/en-us/sgx-sdk/download. The documentation should explain what API has been validated.
