Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Why do I fail to malloc(1600000)?
li__caihua
Hi folk,
Today I found that I fail to malloc(1600000) in enclave (the return value is NULL). Obviously, 1600000 bytes is just about 1.5M.
void printf(const char *fmt, ...)
    const int size = 1600000;
    char* bytearray = NULL;
    bytearray = (char*)malloc(size);
    std::string buf = "OK!\n";
    if (bytearray == NULL) buf = "Fail!\n";
    ocall_print_string(buf.c_str());
Many thanks,
Caihua
Rodolfo_S_
New Contributor III
Can you tell what was the maximum heap size that you set on the config.xml file?
Rodolfo
