Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Why is ld.gold better than ld for intel sgx?
shmoo
The documentation Intel_SGX_Developer_Reference_Linux_2.13.3 suggests:
You are also encouraged to help harden your enclaves, by passing one of the following options to the linker, to put read-only non-executable sections in your own segment:
ld.gold --rosegment
or,
-Wl,-fuse-ld=gold –Wl,--rosegment
Why is it better to use ld.gold?
Wikipedia says:
Fedora has moved gold from binutils into its own package due to concerns it is suffering from bitrot after Google's interest has moved to LLVM.[6]
JesusG_Intel
Hello David,
Read-only non-executable memory segments help prevent buffer overflow and other memory attacks. Attackers cannot write to or execute code in these memory segments. ld.gold has also been reported to be a faster linker than ld. I recommend doing a web search on this topic for more information.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello shmoo,
I am working with engineering on getting clarification on why they recommend using ld.gold. I apologize for the delay.
Sincerely,
Jesus G.
JesusG_Intel
Hello shmoo,
I apologize for the delay. I will reply to this thread as soon as I have an answer.
Sincerely,
Jesus G.
JesusG_Intel
Hello shmoo,
ld.gold is recommended only because it further enforces readonly non-executable segments. It is not necessarily better than ld.
Sincerely,
Jesus G.
shmoo
Hello Jesus,
Thank you for asking the engineering team!
What does it mean, that it further enforces read-only non-executable segments?
Sincerely,
David
JesusG_Intel
Hello David,
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread
