Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Will be updating SGX2 from SGX1 possible in the future?
jaebaek_s_
Hi, as far as I know, currently only SGX1 is available to use and later Intel will release CPU with SGX2.
I am curious updating SGX2 from SGX1 is done only by updating microcode.
If not, must we buy new CPU to use SGX2 (while having a SGX1 machine) ?
Surenthar_S_Intel
SGX2 is supported on future platforms and would require end user to purchase new platforms supporting it. SGX1 to SGX2 update through micro code is not supported.
-Surenthar
Anonymous79
I am currently working in SGX enabled applciations.
I would like to know where i can find documentations for SGX 2.0 (Not an intel SGX-SDK 2.0)
Is that SGX 2.0 enabled processors are released ?
Does SGX 1.0 support Flexile Launch Control and Third Party Attestation services?
May I know what are all the main technical differences between SGX1.0 and SGX2.0?
Thanks in advance:)
