Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
encrypted memory through mmap
Dvorak_d_
Hi Folks, a quick N00b question:
Inside an Enclave, if I allocate memory via malloc, will the allocated pages be encrypted? If yes, does it mean that as long as I'm not doing any ocalls inside the Enclave, all memory is encrypted inside the enclave?
E.g. I can compile/statically link whatever library I need (maybe an openssl without I/O) and use it inside an Enclave without any modification, right?
-Dvorak
Francisco_C_Intel
Yes.
Correct. Note that the enclave itself is not encrypted before it is loaded.
If you have the source for such a library, and you can build it using the SGX SDK, then yes you can link it statically and place it inside an enclave. If your library does end up using any illegal instructions your enclave will fail as described in the reference manuals.
Francisco_C_Intel
Yes.
