Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
from "some.edl" import * EXCEPT...
AArya2
I have the following imports in my enclave definition:
from "sgx_tstdc.edl" import *;
from "sgx_tprotected_fs.edl" import *;
It results in the following errors:
2>CUSTOMBUILD : error : multiple definition of function "sgx_oc_cpuidex" detected.
1>CUSTOMBUILD : error : multiple definition of function "sgx_oc_cpuidex" detected.
What causes this?
If it is because both edl's are defining "sgx_oc_cpuidex", is there a way to exclude that particular function from the set of things imported from one of the edl's? I mean a compact way, without having to enumerate every single function that we WANT to import.
Juan_d_Intel
Unfortunately the EDL doesn't support something like the exclude keyword.
Since sgx_tprotected_fs.edl imports everything from sgx_tae_service.edl, which in turn, imports everything from sgx_tstdc.edl, I think it would be easier if you just remove from "sgx_tstdc.edl" import *; from your enclave EDL.
Juan_d_Intel
