Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
how to get values for PCK certificate in remote attestation
Hszz09
https://api.portal.trustedservices.intel.com/documentation#pcs-certificate
As said in this URL, use curl to pass some values to Intel. However, how can I get the values such as Ocp-Apim-Subscription-Key, encrypted_ppid, cpusvn, pcesvn, pceid.
Is there any script available?
Thanks!
Hszz09
problem solved
Shefali_K_Intel
I am able to get all the pre-requisites needed for PCK Certificate downloading. I got Ocp-Apim-Subscription-Key, encrypted_ppid, cpusvn, pcesvn, pceid. However when I run curl command for retrieval I always get 404 Resource not found. Do you have any idea how to resolve it ??
{ "statusCode": 404, "message": "Resource not found" }
Pratama__Denny_April
HI @Hszz09,
you said that problem solved, may I know how do you get the encrypted_ppid, cpusvn, pcesvn, pceid ?
Akhtar__Maham
Hi can you please share how you solved this problem @Hszz09 ??
Primawan__Andy
Hi all,
so, how we can get those values?
  1. encrypted_ppid
  2. cpusvn
  3. pcesvn
  4. pceid
Primawan__Andy
I just write a guide to get those values:
  1. encrypted_ppid
  2. cpusvn
  3. pcesvn
  4. pceid
You can read the guide in here:
https://github.com/on-premise-signal/signal-setup-guide/blob/master/README.md#get-intel-sgx-pck-certificate
Sturmann__Lilian
The PPID, CPUSVN, PCESVN, PCEID can be retrieved by downloading and running Intel's PCK ID Retrieval Tool on an SGX-capable machine.
The subscription key is obtained by registering for it with Intel.
The API for retrieving the PCK cert will give an invalid key error if you leave the {brackets} around the subscription key. However, you should leave brackets around the PPID, CPUSVN, PCESVN, PCEID.
The SDK and PSW are not necessary for retrieving these values.
