Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
library inside SGX
Roshan_Mehta
Is there any Machine learning library (general purpose) which is supported inside SGX enclave. I wanted to do machine learning analytics inside enclave but do not want to implement the Machine learning algorithms from scratch and directly use a supported machine learning library.
I tried to use http://dlib.net/ (Dlibc) but the code does not build. Is there any way to use this library inside SGX enclave
Roshan_Mehta
Hi Community
I am still waiting for an answer or suggestion.
