Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
memory not protected by SGX enclave
byq
I am building my SGX enclave demo application in Windows. Under Release configuration it compiles and runs successfully, however, when I inspect process memory by ProcessHacker(https://github.com/processhacker), it can read memory in enclave successfully. Why isn't SGX protecting enclave memory?
btw, when i build with Release configuration, it does not generate enclave1.signed.dll, so i copy it from Prerelease. Not sure if this is the problem.
Sahira_Intel
Can you please send over the full project and exact steps/commands so we can reproduce the problem? We are not able to do much debugging based on the images you sent.
Sincerely,
Sahira
